Einleitung
If your RYOBI P501G battery starts failing when using your saw, you may want to think about replacing the component. The failure may be a the battery being completely drained. The replacement of the battery is not too complex. You will need the indicated screwdrivers and a spudger to complete this task. There are no warnings or potential hazards when replacing the pad.
Place your thumb and forefinger on opposite sides at the base of the RYOBI P501G, where the buttons to release the battery are located.
Click on the buttons to release the latches holding the battery in place and connected.
1 Kommentar zur Anleitung
Replacement for Ryobi P501G Cordless Drill Battery
Type: Li-ion
Volt: 18V
Capacity: 6000mAh
Color: Black
Weight: 898g
Dimension: 135.70 x 76.00 x 107.30mm
This drill battery for Ryobi P501G is 100% compatible and will meet or exceeds original specification. This P501G replacement battery made by Amstron has been tested for safety and designed for high performance. go to view more at https://www.drillbattery.co.uk/batterysa...
