Zum Hauptinhalt wechseln
Ryobi P501G Shell Replacement
Was du brauchst
  1. Ryobi P501G Shell Replacement, Blade: Schritt 1, Bild 1 von 1
    • Locate the area where the blade is connected to the motor, where the circular covering is on the Ryobi P501G.
  2. Ryobi P501G Shell Replacement: Schritt 2, Bild 1 von 2 Ryobi P501G Shell Replacement: Schritt 2, Bild 2 von 2
    • Unscrew clockwise and remove the bearing in the middle, connecting the blade to the motor. This will also allow removal of the blade guard.
  3. Ryobi P501G Shell Replacement: Schritt 3, Bild 1 von 3 Ryobi P501G Shell Replacement: Schritt 3, Bild 2 von 3 Ryobi P501G Shell Replacement: Schritt 3, Bild 3 von 3
    • Remove the four black screws holding the black bearing and remove the bearing itself.
  4. Ryobi P501G Shell Replacement: Schritt 4, Bild 1 von 1
    • Once the black bearing is off, remove the transparent cover of the blade.
    • Once the cover is off, remove the blade.
    • Place the new blade with the flat notches lined up with the flat notches on the motor axle.
  5. Ryobi P501G Shell Replacement, Shell: Schritt 5, Bild 1 von 3 Ryobi P501G Shell Replacement, Shell: Schritt 5, Bild 2 von 3 Ryobi P501G Shell Replacement, Shell: Schritt 5, Bild 3 von 3
    • Remove the three screws on the inside base of the metal casing of the blade.
    • Pull the metal blade casing off of the Ryobi P501G body.
  6. Ryobi P501G Shell Replacement: Schritt 6, Bild 1 von 3 Ryobi P501G Shell Replacement: Schritt 6, Bild 2 von 3 Ryobi P501G Shell Replacement: Schritt 6, Bild 3 von 3
    • Remove all of the screws located on the right side of the saw.
    • Separate the right side of the saw from the left side by pulling away once all of the screws are removed.
    • Pull back the shell to access the housed parts underneath.
Abschluss
Cal Poly, Team S1-G2, Maness Spring 2019 Mitglied von Cal Poly, Team S1-G2, Maness Spring 2019
CPSU-MANESS-S19S1G2
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 13
Insgesamt: 554
