Zum Hauptinhalt wechseln
Ryobi P501G Trigger Replacement
Was du brauchst
  1. Ryobi P501G Trigger Replacement, Shell: Schritt 1, Bild 1 von 3 Ryobi P501G Trigger Replacement, Shell: Schritt 1, Bild 2 von 3 Ryobi P501G Trigger Replacement, Shell: Schritt 1, Bild 3 von 3
    • Remove the three screws on the inside base of the metal casing of the blade.
    • Pull the metal blade casing off of the Ryobi P501G body.
  2. Ryobi P501G Trigger Replacement: Schritt 2, Bild 1 von 3 Ryobi P501G Trigger Replacement: Schritt 2, Bild 2 von 3 Ryobi P501G Trigger Replacement: Schritt 2, Bild 3 von 3
    • Remove all of the screws located on the right side of the saw.
    • Separate the right side of the saw from the left side by pulling away once all of the screws are removed.
    • Pull back the shell to access the housed parts underneath.
  3. Ryobi P501G Trigger Replacement, Trigger: Schritt 3, Bild 1 von 1
    • After opening the shell, locate the black plastic trigger on the handle of the device.
  4. Ryobi P501G Trigger Replacement: Schritt 4, Bild 1 von 1
    • Remove the black wiring and the trigger is free! Reposition it however you'd like or switch it out with a new one.
    • Make sure the trigger is snug and exactly where you want it. A dislodged trigger can be very dangerous in a power saw!
Abschluss
Sophia Arias
255 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S1-G2, Maness Spring 2019 Mitglied von Cal Poly, Team S1-G2, Maness Spring 2019
CPSU-MANESS-S19S1G2
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 3
Letzte 30 Tage: 20
Insgesamt: 1,675
