Einleitung
Use this guide to replace the finger trigger in your Ryobi P501G.
Was du brauchst
Remove the three screws on the inside base of the metal casing of the blade.
Pull the metal blade casing off of the Ryobi P501G body.
Remove all of the screws located on the right side of the saw.
Separate the right side of the saw from the left side by pulling away once all of the screws are removed.
Pull back the shell to access the housed parts underneath.
After opening the shell, locate the black plastic trigger on the handle of the device.
Remove the black wiring and the trigger is free! Reposition it however you'd like or switch it out with a new one.
