Was du brauchst
Use a Torx T5 screwdriver to remove the single 8 mm screw securing the shoe.
Use a Torx T5 screwdriver to remove the six screws on the underside of the device.
Use a Torx T5 screwdriver to remove the four screws on the top of the gear case.
Insert needle nose pliers to remove the retaining pin at the top of the bearing.
Once the retaining pin has been removed, pull off the damaged bearing and insert a new one.
2 weitere Personen haben diese Anleitung absolviert.
