Zum Hauptinhalt wechseln
Ryobi RJ1861V Motor Replacement
Was du brauchst
  1. Ryobi RJ1861V Motor Replacement, Saw Bar Assembly: Schritt 1, Bild 1 von 1
    • Use a Torx T5 screwdriver to remove the single 8 mm screw securing the shoe.
  2. Ryobi RJ1861V Motor Replacement: Schritt 2, Bild 1 von 2 Ryobi RJ1861V Motor Replacement: Schritt 2, Bild 2 von 2
    • Remove the rubber sleeve.
    • You may have to use some force as it has a tight fit.
  3. Ryobi RJ1861V Motor Replacement: Schritt 3, Bild 1 von 1
    • Use a Torx T5 screwdriver to remove the six screws on the underside of the device.
  4. Ryobi RJ1861V Motor Replacement: Schritt 4, Bild 1 von 1
    • Use a Torx T5 screwdriver to remove the four screws on the top of the gear case.
    • There are two screws on each side of the device.
  5. Ryobi RJ1861V Motor Replacement: Schritt 5, Bild 1 von 1
    • Remove the backside panel.
  6. Ryobi RJ1861V Motor Replacement: Schritt 6, Bild 1 von 1
    • Unscrew the four T5 Torx screws that hold the assembly bar in place.
  7. Ryobi RJ1861V Motor Replacement: Schritt 7, Bild 1 von 1
    • Lift the assembly bar up and out of the chassis.
  8. Ryobi RJ1861V Motor Replacement, Assembly Bar Bearing: Schritt 8, Bild 1 von 1
    • Begin with the top of the device facing up.
  9. Ryobi RJ1861V Motor Replacement: Schritt 9, Bild 1 von 1
    • Insert needle nose pliers to remove the retaining pin at the top of the bearing.
  10. Ryobi RJ1861V Motor Replacement: Schritt 10, Bild 1 von 1
    • Once the retaining pin has been removed, pull off the damaged bearing and insert a new one.
  11. Ryobi RJ1861V Motor Replacement, Motor: Schritt 11, Bild 1 von 1
    • The motor is divided into two sections, one attached to the gear case and one attached to the handle.
    • This arrow indicates the section attached to the gear case.
    • This arrow indicates the section attached to the handle.
  12. Ryobi RJ1861V Motor Replacement: Schritt 12, Bild 1 von 3 Ryobi RJ1861V Motor Replacement: Schritt 12, Bild 2 von 3 Ryobi RJ1861V Motor Replacement: Schritt 12, Bild 3 von 3
    • Use a Torx T5 screwdriver to remove the four screws attaching the motor to the gear case.
  13. Ryobi RJ1861V Motor Replacement: Schritt 13, Bild 1 von 1
    • Use a Torx T5 screwdriver to remove the two screws inside the motor housing of the handle.
  14. Ryobi RJ1861V Motor Replacement: Schritt 14, Bild 1 von 2 Ryobi RJ1861V Motor Replacement: Schritt 14, Bild 2 von 2
    • Remove the four screws on the back of the housing with a Torx T5 screwdriver.
    • Flip the housing over and pull the motor up and out of the housing.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Adrian Williams
183 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 3
Letzte 30 Tage: 29
Insgesamt: 259
