Einleitung
If your Ryobi RS290G bearing assembly is loose or causing traction pad issues, this guide will show you how to successfully replace the bearing assembly.
Was du brauchst
Using a TR20 Torx security screwdriver, remove the four 6mm screws.
After removing the backing pad, carefully pull on the rubber brake to remove it from the housing assembly.
Using a TR 20 Torx security screwdriver, remove the single 3mm screw in the center of the bearing cap assembly.
To reassemble your device, follow these instructions in reverse order. Make sure to tighten down properly to avoid loose or traction pad issues.
