Einleitung
If your Ryobi RS290G Brush Assemblies are no longer working, this guide will show you how to successfully replace them.
Was du brauchst
Remove two 20mm and one 16mm Phillips #2 screws from the housing assembly and exhaust port.
Slide the power switch out of the housing assembly by carefully gripping the power switch and slide upward from the base.
Carefully slide the housing assembly apart, avoiding damage or pulling on wires.
