Zum Hauptinhalt wechseln
Ryobi RS290G Motor Replacement
Was du brauchst
  1. Ryobi RS290G Motor Replacement, Top Cap: Schritt 1, Bild 1 von 1
    • Remove two 20mm and one 16mm Phillips #2 screws from the housing assembly and exhaust port.
  2. Ryobi RS290G Motor Replacement: Schritt 2, Bild 1 von 1
    • Remove the three 16mm Phillips #2 screws from the top cap/upper grip.
  3. Ryobi RS290G Motor Replacement: Schritt 3, Bild 1 von 1
    • Remove the top cap.
  4. Ryobi RS290G Motor Replacement, Switch Trigger: Schritt 4, Bild 1 von 1
    • Remove the switch trigger.
  5. Ryobi RS290G Motor Replacement, Motor: Schritt 5, Bild 1 von 1
    • Remove the two 16mm Phillips #2 screws from the inner housing assembly.
  6. Ryobi RS290G Motor Replacement: Schritt 6, Bild 1 von 1
    • Remove the two 14mm Phillips #2 screws from the cord clamp.
  7. Ryobi RS290G Motor Replacement: Schritt 7, Bild 1 von 2 Ryobi RS290G Motor Replacement: Schritt 7, Bild 2 von 2
    • Slide the power switch out of the housing assembly.
  8. Ryobi RS290G Motor Replacement: Schritt 8, Bild 1 von 1
    • Carefully slide the housing assembly apart, avoiding damage or pulling on wires.
  9. Ryobi RS290G Motor Replacement: Schritt 9, Bild 1 von 2 Ryobi RS290G Motor Replacement: Schritt 9, Bild 2 von 2
    • Slide off the disconnect terminal for the switch (red lead) from the power switch using the flat end of a spudger.
  10. Ryobi RS290G Motor Replacement: Schritt 10, Bild 1 von 2 Ryobi RS290G Motor Replacement: Schritt 10, Bild 2 von 2
    • Slide out the brush assembly with the black lead from the inner housing assembly.
  11. Ryobi RS290G Motor Replacement: Schritt 11, Bild 1 von 1
    • Slide off the disconnect terminal for the brush assembly (black lead) from the brush assembly.
    • You may need an ESD-safe flat edge tool, such as a spudger, to help slide off the disconnect terminal. Be careful not to damage the pieces or yourself.
  12. Ryobi RS290G Motor Replacement: Schritt 12, Bild 1 von 1
    • Remove the armature assembly, with the motor, out of the inner housing assembly.
  13. Ryobi RS290G Motor Replacement: Schritt 13, Bild 1 von 3 Ryobi RS290G Motor Replacement: Schritt 13, Bild 2 von 3 Ryobi RS290G Motor Replacement: Schritt 13, Bild 3 von 3
    • Replace the motor (also known as field assembly).
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 15
Insgesamt: 1,040
