Was du brauchst
Unscrew the two phillips head screws. Use the reversible screwdriver that came with the car.
Pull the cover up and slightly to the right.
Here we have to replace the filter. Lift the filter up. It comes off without difficulty.
Clean all of the rubbish and insects that are inside.
Place the new filter, fitting the rubber contour with the gap.
Fit the two tabs in their places.
Once you've done that, put the two screws into their places and tightly screw them in. Finally, check to see that they are completely screwed in.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Mr. Bean hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
