Einleitung
This guide will help you replace the back cover of you controller. You’ll only need a Phillips #000 screwdriver to complete this guide.
Was du brauchst
Hold the controller with the bottom plate facing up, and gently remove the top plate that is connected to the motherboard of the controller. Set the top plate aside.
Remove the screws on the back of the controller with the Phillips #000 screwdriver.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
