Zum Hauptinhalt wechseln
SG 552-1 Commando Barrel Replacement
Was du brauchst
  1. SG 552-1 Commando Barrel Replacement, Barrel: Schritt 1, Bild 1 von 2 SG 552-1 Commando Barrel Replacement, Barrel: Schritt 1, Bild 2 von 2
    • Using a flathead screwdriver, remove the pin holding the hand guard in place.
    • To remove this, turn the pin clockwise and push it through at the same time.
    • Pull the hand guard off.
  2. SG 552-1 Commando Barrel Replacement: Schritt 2, Bild 1 von 2 SG 552-1 Commando Barrel Replacement: Schritt 2, Bild 2 von 2
    • Using a Phillips #1 screwdriver, remove the two 8mm screws above the hand guard on both sides of the gun. There should be four total.
  3. SG 552-1 Commando Barrel Replacement: Schritt 3, Bild 1 von 2 SG 552-1 Commando Barrel Replacement: Schritt 3, Bild 2 von 2
    • Locate the button to fold over the folding stock and fold over the folding stock.
    • Using a Phillips #1 screwdriver, remove the 20mm screw located behind the folding stock.
  4. SG 552-1 Commando Barrel Replacement: Schritt 4, Bild 1 von 2 SG 552-1 Commando Barrel Replacement: Schritt 4, Bild 2 von 2
    • Turn the gun over so that you are facing the bottom of the gun.
    • Using a Phillips #1 screwdriver, remove the following screws:
    • Remove the 8mm screw located directly underneath the cocking lever.
    • Remove the 8mm screw beside the one you just removed.
  5. SG 552-1 Commando Barrel Replacement: Schritt 5, Bild 1 von 2 SG 552-1 Commando Barrel Replacement: Schritt 5, Bild 2 von 2
    • Carefully tug on the tip of the gun and pull the barrel and its cover out.
  6. SG 552-1 Commando Barrel Replacement: Schritt 6, Bild 1 von 3 SG 552-1 Commando Barrel Replacement: Schritt 6, Bild 2 von 3 SG 552-1 Commando Barrel Replacement: Schritt 6, Bild 3 von 3
    • Pull the barrel out from the cover.
    • Remove the pieces at the end of the barrel.
  7. SG 552-1 Commando Barrel Replacement: Schritt 7, Bild 1 von 2 SG 552-1 Commando Barrel Replacement: Schritt 7, Bild 2 von 2
    • Remove the remaining pieces of on the ends of the barrel.
Abschluss
Laura Schulz
1 Reputation
1 Anleitung geschrieben
Cal Poly, Team 18-41, Regan Fall 2012 Mitglied von Cal Poly, Team 18-41, Regan Fall 2012
CPSU-REGAN-F12S18G41
6 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 1,673
