Zum Hauptinhalt wechseln
SHARK WANDVAC WV205 Battery Replacement
Was du brauchst
  1. SHARK WANDVAC WV205 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 SHARK WANDVAC WV205 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Push the sliding button to open the dirt capsule to empty it out.
    • Ensure to do this over a garbage can/bag to prevent a mess.
  2. SHARK WANDVAC WV205 Battery Replacement: Schritt 2, Bild 1 von 2 SHARK WANDVAC WV205 Battery Replacement: Schritt 2, Bild 2 von 2
    • Using a coin or other thin item, such as a guitar pick, push the cap at the end of the vacuum out. Switch between sides to make it come out evenly.
    • This could take more time than expected.
  3. SHARK WANDVAC WV205 Battery Replacement: Schritt 3, Bild 1 von 2 SHARK WANDVAC WV205 Battery Replacement: Schritt 3, Bild 2 von 2
    • Once the battery is popped out, carefully pull it out.
  4. SHARK WANDVAC WV205 Battery Replacement: Schritt 4, Bild 1 von 2 SHARK WANDVAC WV205 Battery Replacement: Schritt 4, Bild 2 von 2
    • To properly store and then dispose of the battery put it in a clear plastic bag.
  5. SHARK WANDVAC WV205 Battery Replacement: Schritt 5, Bild 1 von 2 SHARK WANDVAC WV205 Battery Replacement: Schritt 5, Bild 2 von 2
    • Slot your replacement battery where the old one was.
    • Once inside, push hard on the end until you hear a click.
  6. SHARK WANDVAC WV205 Battery Replacement: Schritt 6, Bild 1 von 1
    • Test the vacuum to ensure the replacement succeeded.
Abschluss
To properly dispose of the old battery consult your cities policies on lithium ion battery disposal.
Eine weitere Person hat diese Anleitung absolviert.
Nicolaas
160 Reputation
1 Anleitung geschrieben
York University, Team P-22, O'Regan Winter 2024 Mitglied von York University, Team P-22, O'Regan Winter 2024
YORK-O'REGAN-W24SPG22
1 Mitglied
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 24
Letzte 30 Tage: 105
Insgesamt: 1,586
