Zum Hauptinhalt wechseln
SHARP EL-W53XG WriteView Battery Replacement
Was du brauchst
  1. SHARP EL-W53XG WriteView  Battery Replacement, Battery: Schritt 1, Bild 1 von 2 SHARP EL-W53XG WriteView  Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn off the calculator by pressing both the [2NDF ] and [ON] buttons at the same time.
  2. SHARP EL-W53XG WriteView  Battery Replacement: Schritt 2, Bild 1 von 1
    • Flip the calculator so that the battery cover is facing you, and it will be easy to remove.
  3. SHARP EL-W53XG WriteView  Battery Replacement: Schritt 3, Bild 1 von 2 SHARP EL-W53XG WriteView  Battery Replacement: Schritt 3, Bild 2 von 2
    • Remove the two screws securing the battery cover with the Tri-point #000 screwdriver.
    • Remove the battery cover.
    • Make sure not to remove the other screws on the calculator, just the two screws on the battery cover.
  4. SHARP EL-W53XG WriteView  Battery Replacement: Schritt 4, Bild 1 von 2 SHARP EL-W53XG WriteView  Battery Replacement: Schritt 4, Bild 2 von 2
    • Remove the worn-out LR44 battery inside using a spudger.
  5. SHARP EL-W53XG WriteView  Battery Replacement: Schritt 5, Bild 1 von 1
    • Gently insert the new LR44 battery in the empty battery slot.
  6. SHARP EL-W53XG WriteView  Battery Replacement: Schritt 6, Bild 1 von 1
    • Place and screw the battery cover on using the Tri-point #000 screwdriver.
    • Tightly screw the battery cover to prevent losing screws.
Abschluss
Faduma Hagi
133 Reputation
1 Anleitung geschrieben
York University, Team 1-7, O'Regan Fall 2021 Mitglied von York University, Team 1-7, O'Regan Fall 2021
YORK-O'REGAN-F21S1G7
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 34
Insgesamt: 1,519
