Was du brauchst
Entferne die vier Kreuzschlitzschrauben, dann kannst du den Boden abnehmen.
Biege die Kunststoffhalterungen mit einem Schlitzschraubendreher vorsichtig zur Seite und hebe die Verriegelung vorsichtig heraus.
Entferne die Reste der alten Wellenscheibe und beseitige alle Korrosionsspuren, bevor du die neue M34x 41 x 0,5 mm Wellenscheibe wieder einlegst.
Lasse die Verriegelung wieder einrasten und schraube die Einheit wieder zusammen.
3 weitere Personen haben diese Anleitung absolviert.
100%
VauWeh hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
5 Kommentare zur Anleitung
I bought the wave washer via ebay (10 pieces) and replaced it as described here. Only residues from the old one were remaining...
Now the closing mechanism of the blade feels firm again and (so far) no leakage was observed.
Thanks!
The black wave washers tend to rust pretty quickly, I managed to find stainless steel ones on aliexpress but haven't been able to test them properly due to now having issues with the plastic retainers. I found the latch started getting corroded and its use damaged the plastic retainers so it doesn't hold as well as it used to. I'm wondering if the latch is suffering from galvanic corrosion during dishwasher use.
I have the same problem with corroded latch. Did you find any solution?
A new washer fixed the problem. I found suitable ones on Aliexpress out of Stainless steel. https://s.click.aliexpress.com/e/_DFnIus...
M34x41 Size
The German word for the replacement is "Federwellenring" or "Federring ". When searching for it don't use "Monsieur Cuisine" the are a general replacement part.
