Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
How to Unlock Sony XPERIA SIM Network Lock.
Einführungsvideo
  1. Make sure your phone is locked and is prompting you for a network code when a non-supported sim is inserted. Check the lock status: From Phone dealer enter this code - *#*#7378423#*#*
    • Make sure your phone is locked and is prompting you for a network code when a non-supported sim is inserted.
    • Check the lock status:
    • From Phone dealer enter this code - *#*#7378423#*#*
    • > Service info
    • > SIM lock
  2. Confirm your phone is eligible for the service. There should be an "X" before Network and the counter should show number above 0 (zero). If your counter doesn't show an "X" or shows 0 (zero) this means your phone is hardlocked and it CAN'T BE unlocked by a code. Obtain your 15-digit IMEI by dialing *#06#. Never get the IMEI from elsewhere, as it could be different from the actual IMEI.
    • Confirm your phone is eligible for the service.
    • There should be an "X" before Network and the counter should show number above 0 (zero). If your counter doesn't show an "X" or shows 0 (zero) this means your phone is hardlocked and it CAN'T BE unlocked by a code.
    • Obtain your 15-digit IMEI by dialing *#06#. Never get the IMEI from elsewhere, as it could be different from the actual IMEI.
  3. iPhone LCD Display Fix Kits
    Die Budgetoption, abgedeckt durch unsere lebenslange Garantie.
    Kits kaufen
    Reduziere die Reparaturkosten, nicht die Qualität.
    Kits kaufen
  4. Enter the code provided and your handset is unlocked! Enter the code provided and your handset is unlocked! Enter the code provided and your handset is unlocked!
    • Enter the code provided and your handset is unlocked!
  5. That's all!
    • That's all!
Abschluss
23 weitere Nutzer haben diese Anleitung absolviert.
ZFix
169.724 Reputation
306 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
293 Mitglieder
841 Anleitungen geschrieben
MySony experia show me (1) on network sim status……ths can be unlocked ?
sumclis william - Antwort
I unlocked my Sony E5 yesterday using this website https://store.unlockboot.com/unlock-sony...
Stephan Popov - Antwort
I recommend this service here to unlock your Sony XPERIA phone https://www.imeiunlocksim.com/unlock-pho...
They are great professionals in this job, have wonderful and very very fast support.
Adams Bell - Antwort
i also got the same problem but seems to be worse my sony phone is hard locked and is showing 0 on the network option. how can i fix this
henry - Antwort
My Sony is showing me zero how can I fix it
Osusu Felicia -
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 47
Letzten 7 Tage: 349
Letzten 30 Tage: 1,314
Insgesamt: 21,069
