Einleitung
This guide will walk you through replacing your battery.
Was du brauchst
Prior to any repairs make sure that you are familiar with the device as well as the location of its buttons and ports.
Insert the plastic opening tool between the bottom seam of the back panel and the micro SD port. The tool's edge should point toward the rear panel to prevent any scratching or damage.
Follow up with the plastic opening tool, releasing the clips as you go all the way around the device.
The clips will be released in the order specified as the spudger tool is moved along the seam around the device.
Use a plastic opening tool to pry the speakers out of the rear case.
The rear case will now be free from the rest of the device.
Use a soldering iron and desoldering braid to desolder the red and black motherboard battery connections.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Great Instructions! where did you get the battery for the Skytex ?
