Zum Hauptinhalt wechseln
SKYTEX SP1020 Motherboard Replacement
Was du brauchst
  1. SKYTEX SP1020 Motherboard Replacement, Rear Case: Schritt 1, Bild 1 von 2 SKYTEX SP1020 Motherboard Replacement, Rear Case: Schritt 1, Bild 2 von 2
    • Prior to any repairs make sure that you are familiar with the device as well as the location of its buttons and ports.
    • Turn off device prior to continuing to further steps.
  2. SKYTEX SP1020 Motherboard Replacement: Schritt 2, Bild 1 von 3 SKYTEX SP1020 Motherboard Replacement: Schritt 2, Bild 2 von 3 SKYTEX SP1020 Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Set the tablet back panel facing down, with the SKYTEX logo facing you. You will find that this step will start from the right side of the device.
    • Insert the plastic opening tool between the bottom seam of the back panel and the micro SD port. The tool's edge should point toward the rear panel to prevent any scratching or damage.
    • Follow up with the plastic opening tool, releasing the clips as you go all the way around the device.
  3. SKYTEX SP1020 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • The clips will be released in the order specified as the spudger tool is moved along the seam around the device.
  4. SKYTEX SP1020 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Use a plastic opening tool to pry the speakers out of the rear case.
    • The rear case will now be free from the rest of the device.
  5. SKYTEX SP1020 Motherboard Replacement, Battery: Schritt 5, Bild 1 von 1
    • Locate the battery.
  6. SKYTEX SP1020 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Use a soldering iron and desoldering braid to desolder the red and black motherboard battery connections.
  7. SKYTEX SP1020 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Gently lift the battery up and out of the device.
  8. SKYTEX SP1020 Motherboard Replacement, Speakers: Schritt 8, Bild 1 von 1
    • locate the speakers
  9. SKYTEX SP1020 Motherboard Replacement: Schritt 9, Bild 1 von 2 SKYTEX SP1020 Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Use a soldering iron and desoldering braid to desolder the two sets of red and black wires.
  10. SKYTEX SP1020 Motherboard Replacement: Schritt 10, Bild 1 von 1
  11. SKYTEX SP1020 Motherboard Replacement, Motherboard: Schritt 11, Bild 1 von 1
    • Become familiar with the motherboard including its attachable components and wires.
    • The image shows and specify the order of the major components that must be removed before moving on.
  12. SKYTEX SP1020 Motherboard Replacement: Schritt 12, Bild 1 von 3 SKYTEX SP1020 Motherboard Replacement: Schritt 12, Bild 2 von 3 SKYTEX SP1020 Motherboard Replacement: Schritt 12, Bild 3 von 3
    • Locate the two ribbon cables that will need to be removed.
    • Using the spudger tool, slide the black clip over the white housing up. This will release the ribbon cable.
    • Once the ribbon cable is loose, the tweezers should be used to slide the cable out.
    • Don't grab the ribbon cable too hard, to avoid any damage to the cable.
  13. SKYTEX SP1020 Motherboard Replacement: Schritt 13, Bild 1 von 2 SKYTEX SP1020 Motherboard Replacement: Schritt 13, Bild 2 von 2
    • Locate the set of wires with a white coating located at the bottom of the motherboard.
    • Using the tweezers carefully remove the cables one at a time from the motherboard.
    • Avoid any damage to the tips of the wires.
  14. SKYTEX SP1020 Motherboard Replacement: Schritt 14, Bild 1 von 1
    • Using the tweezers remove the single white coated wire from the motherboard with a split at the tip.
    • When removing the wire, you want to mark one of the tips thats removed first with tape. The motherboard will have a "+" and a "-" sign attached to the wires mark them once removed to help with the reassembling process.
  15. SKYTEX SP1020 Motherboard Replacement: Schritt 15, Bild 1 von 1
    • Using the (3.75mm) Phillips #00 screwdriver remove all of the indicated screws connecting the motherboard to the case.
  16. SKYTEX SP1020 Motherboard Replacement: Schritt 16, Bild 1 von 1
    • Reattach the single white coated wire using a soldering kit.
    • Be sure to solder the positive "+" and negative "-" ports to their corresponding places.
  17. SKYTEX SP1020 Motherboard Replacement: Schritt 17, Bild 1 von 1
    • Using a soldering kit attach the set of white coated wires back to the new motherboard.
    • When soldering the wires, be sure to not let the solder touch between the four tips, to avoid a shorted circuit.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
yuriy16899
243 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 1-6, Miles Spring 2015 Mitglied von UMass Dartmouth, Team 1-6, Miles Spring 2015
UMASSD-MILES-S15S1G6
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 478
