Zum Hauptinhalt wechseln
SM Santa Marin hand watch Battery Replacement
Was du brauchst
  1. SM Santa Marin hand watch Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Take apart the steel strap for the watch by using the round head (SIM) screwdriver. Then pull out the screw.
  2. SM Santa Marin hand watch Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove four screws from the back cover using the Y000 screwdriver .
  3. SM Santa Marin hand watch Battery Replacement: Schritt 3, Bild 1 von 1
    • Remove the back cover of the watch using the opening tool.
  4. SM Santa Marin hand watch Battery Replacement: Schritt 4, Bild 1 von 1
    • Remove the plastic gasket from on top of the battery using the opening tool.
  5. SM Santa Marin hand watch Battery Replacement: Schritt 5, Bild 1 von 1
    • Loosen the battery bracket from the watch by placing the 1mm flathead screwdriver under and lifting carefully.
  6. SM Santa Marin hand watch Battery Replacement: Schritt 6, Bild 1 von 2 SM Santa Marin hand watch Battery Replacement: Schritt 6, Bild 2 von 2
    • Take the old battery out using the plastic opening tool or spudger.
Abschluss
Aziz Zabarmawi
133 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 45
Insgesamt: 861
