Zum Hauptinhalt wechseln
SONY Alpha NEX-3N Flash Assembly Replacement
Was du brauchst
    1. SONY Alpha NEX-3N Flash Assembly Replacement, Getting Started: Schritt 1, Bild 1 von 2 SONY Alpha NEX-3N Flash Assembly Replacement, Getting Started: Schritt 1, Bild 2 von 2
      • Remove battery and card
      Frag FixBot
      Kommentar hinzufügen
    2. SONY Alpha NEX-3N Flash Assembly Replacement, Back Case 1: Schritt 2, Bild 1 von 3 SONY Alpha NEX-3N Flash Assembly Replacement, Back Case 1: Schritt 2, Bild 2 von 3 SONY Alpha NEX-3N Flash Assembly Replacement, Back Case 1: Schritt 2, Bild 3 von 3
      • Right side, remove 1 M1.4x3.7 screw
      • Left side, remove 3 M1.4x3.7 screws
      • Bottom side, remove 5 M1.4x3.7 screws, including 2 in battery bay. 2 of them out of this photo, you can find them.
      • Do NOT touch screws on the bottom of LCD assembly.
      Frag FixBot
    3. SONY Alpha NEX-3N Flash Assembly Replacement, Back Case 2: Schritt 3, Bild 1 von 1
      • Pop the flash.
      • In flash room, remove 1 (one) M1.4x3.8 black screw.
      Frag FixBot
    4. SONY Alpha NEX-3N Flash Assembly Replacement, Back Case 3: Schritt 4, Bild 1 von 3 SONY Alpha NEX-3N Flash Assembly Replacement, Back Case 3: Schritt 4, Bild 2 von 3 SONY Alpha NEX-3N Flash Assembly Replacement, Back Case 3: Schritt 4, Bild 3 von 3
      • Remove LCD hinge cover, by sliding to the left.
      • Remove back cover, actually just a plastic frame.
      Frag FixBot
    5. SONY Alpha NEX-3N Flash Assembly Replacement, LCD assembly: Schritt 5, Bild 1 von 2 SONY Alpha NEX-3N Flash Assembly Replacement, LCD assembly: Schritt 5, Bild 2 von 2
      • Remove 1 M1.4x2 screw
      • Remove another M1.4x2 screw, sorry for the angle.
      Frag FixBot
    6. SONY Alpha NEX-3N Flash Assembly Replacement, LCD Assembly: Schritt 6, Bild 1 von 3 SONY Alpha NEX-3N Flash Assembly Replacement, LCD Assembly: Schritt 6, Bild 2 von 3 SONY Alpha NEX-3N Flash Assembly Replacement, LCD Assembly: Schritt 6, Bild 3 von 3
      • CAUTION. Sony makes world's MOST BRITTLE FPC!
      • Loosen LCD assemble with caution!
      • Release FPC cable, the connector is flip type.
      Frag FixBot
    7. SONY Alpha NEX-3N Flash Assembly Replacement, The LCD assembly: Schritt 7, Bild 1 von 1
      • The LCD assembly
      Frag FixBot
    8. SONY Alpha NEX-3N Flash Assembly Replacement, Dismantle the LCD Part: Schritt 8, Bild 1 von 3 SONY Alpha NEX-3N Flash Assembly Replacement, Dismantle the LCD Part: Schritt 8, Bild 2 von 3 SONY Alpha NEX-3N Flash Assembly Replacement, Dismantle the LCD Part: Schritt 8, Bild 3 von 3
      • After unscrew 4pcs screw you will remove the steel black plate, then slowly pull the black frame there to see the ribbon stripe.
      • Slowly pull the very fragile ribbon lock which i marking with the blue boxes. around just 1mm to unlock the ribbon.. unlucky i broke mine..
      Frag FixBot
    9. SONY Alpha NEX-3N Flash Assembly Replacement, Dismantle the LCD Part: Schritt 9, Bild 1 von 3 SONY Alpha NEX-3N Flash Assembly Replacement, Dismantle the LCD Part: Schritt 9, Bild 2 von 3 SONY Alpha NEX-3N Flash Assembly Replacement, Dismantle the LCD Part: Schritt 9, Bild 3 von 3
      • you can see the ribbon already pull out but be carefull with the others 2 ribbon when your try to pull out this ribbon.
      • the the circle marker that show others ribbon you need to be carefull. goodluck!
      Frag FixBot
    1. SONY Alpha NEX-3N Flash Assembly Replacement, Screws: Schritt 10, Bild 1 von 1
      • Remove 3 M1.4x3.6 black screws, 2 of them out of focus
      Frag FixBot
    2. SONY Alpha NEX-3N Flash Assembly Replacement: Schritt 11, Bild 1 von 2 SONY Alpha NEX-3N Flash Assembly Replacement: Schritt 11, Bild 2 von 2
      • Slide the flash assembly backwards with caution.
      • Detach flash FPC by pulling it out of the socket.
      • High Voltage! Do NOT touch metal on FPC.
      • Then remove the flash assembly.
      Frag FixBot
    3. SONY Alpha NEX-3N Flash Assembly Replacement: Schritt 12, Bild 1 von 1
      • Remove that part whatever called, by sliding it backwards.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Terrance
7.063 Reputation
19 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 40
Insgesamt: 1,067
