Einleitung
The following guide details steps on how to reach your SONY Ericsson's motherboard. Once you reach the motherboard, you can identify issues the part may have.
  1. Flick the two lock tabs into the unlocked positions by pushing each button forward.
    • Flick the two lock tabs into the unlocked positions by pushing each button forward.
  2. Pop the back cover up using the groove on the top of the phone.
    • Pop the back cover up using the groove on the top of the phone.
  3. You can now access the phone's battery.
    • You can now access the phone's battery.
    • Using a spudger, remove the battery and set it aside.
  4. Remove the two small rubber pieces that cover the lower screws. Using a T-6 Torx wrench or screwdriver, remove all four of the small screws at the top and bottom corners on the back of the phones.
    • Remove the two small rubber pieces that cover the lower screws.
    • Using a T-6 Torx wrench or screwdriver, remove all four of the small screws at the top and bottom corners on the back of the phones.
  5. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  6. Gently pry off the faceplate using a plastic opening tool.
    • Gently pry off the faceplate using a plastic opening tool.
    • Insert the plastic opening tool into the middle of the front and back panels of the phone.
  7. Seperate the front and back panels that were pryed open with the plastic opening tool.
    • Seperate the front and back panels that were pryed open with the plastic opening tool.
  8. Now that the faceplate is off, use tweezers to separate the backplate from the inner manifold.
    • Now that the faceplate is off, use tweezers to separate the backplate from the inner manifold.
  9. With both insides of the phone exposed, gently detach the ribbon cable connecting the two inner sides. You can now separate the two sides of the phone.
    • With both insides of the phone exposed, gently detach the ribbon cable connecting the two inner sides. You can now separate the two sides of the phone.
  10. The motherboard is located on the side with the green and black bumper on the bottom. Use the plastic opening tool to pry the bumper off.
    • The motherboard is located on the side with the green and black bumper on the bottom. Use the plastic opening tool to pry the bumper off.
  11. To remove the motherboard, apply upwards pressure on the bottom green tab.
    • To remove the motherboard, apply upwards pressure on the bottom green tab.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Bob
301 Reputation
3 Anleitungen geschrieben
SUNY Cortland, Team 1-3, Getto Spring 2013 Mitglied von SUNY Cortland, Team 1-3, Getto Spring 2013
SUNYCORT-GETTO-S13S1G3
3 Mitglieder
8 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 584
