Zum Hauptinhalt wechseln
SONY ZS-BTG900 Remote Motherboard Replacement
Was du brauchst
  1. SONY ZS-BTG900 Remote Motherboard Replacement, Remote Motherboard: Schritt 1, Bild 1 von 2 SONY ZS-BTG900 Remote Motherboard Replacement, Remote Motherboard: Schritt 1, Bild 2 von 2
    • Flip the remote and remove the backing.
  2. SONY ZS-BTG900 Remote Motherboard Replacement: Schritt 2, Bild 1 von 2 SONY ZS-BTG900 Remote Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Locate the screw behind the battery pack.
    • Use a Phillips size 1 screwdriver to remove the 5/16in screw located inside the battery port.
  3. SONY ZS-BTG900 Remote Motherboard Replacement: Schritt 3, Bild 1 von 2 SONY ZS-BTG900 Remote Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Use the plastic opening tool along the seam on the side of the remote until you hear a click. This means that the plastic tabs holding the remote together are coming loose.
    • Do this until the top half of the remote comes loose.
  4. SONY ZS-BTG900 Remote Motherboard Replacement: Schritt 4, Bild 1 von 2 SONY ZS-BTG900 Remote Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Carefully remove the top to reveal the button covers and the remote control board.
  5. SONY ZS-BTG900 Remote Motherboard Replacement: Schritt 5, Bild 1 von 2 SONY ZS-BTG900 Remote Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Lift the chip out of the plastic casing to replace it.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 449
