Einleitung
Subwoofers are notorious for blowing out. Consistent use at low frequencies result in a short life span for these parts.
This guide will show you how to replace the subwoofer instead of having to throw out you entire device. A replacement subwoofer can be found online or salvaged from another device.
Was du brauchst
Lift up the handle to reveal the screws.
Use your Phillips #2 screwdriver to remove the eight 1/2 inch screws.
Flip your device over.
Use your Phillips #2 screwdriver to remove the six 3/4inch screws.
Flip your device back over to access the top of the device.
Use your plastic opening tool to pry up and remove the panel on the top, left hand side of the device.
Use your Phillips #2 screwdriver to remove the two 1/2 inch screws underneath the now-removed panels.
Once you have removed the top, we will begin removing the front of the device.
Begin by disconnecting the 6 cables that lead from the front of the device to the motherboard.
Use your Philips #2 screwdriver to remove the two 1 inch screws on the outermost part of the device.
Use your Philips #2 screwdriver to remove the two 3/4 inch screws on the outermost part of the device.
Use your Philips #2 screwdriver to remove the one 5/6 inch screw on the middle part of the device.
Begin with the front component after the disassembly prerequisite.
This guide is for the subwoofer seen in the middle of this image.
Desolder the two connector wires off the bottom plate on the speaker.
Note where each cable connects.
Eine weitere Person hat diese Anleitung absolviert.
