Zum Hauptinhalt wechseln
STB-101 Miele Turbo Mini TurboBrush Disassembly and Cleaning
Was du brauchst
  1. STB-101 Miele Turbo Mini TurboBrush Disassembly and Cleaning, Overview: Schritt 1, Bild 1 von 1
    • Here is a photo of the entire unit fully disassembled. Most of the hair we need to get at is inside the ends of the brush axle (bottom left of photo).
    • I recommend using a medium-large safety pin to dig out the hair/fibres, a pair of scissors to cut the hair off of the brush, and a flat head screw driver to pry the black plastic end caps off with. You may need a small hammer for reassembly.
    • There are no screws. Most pieces are held together by plastic pressure. Be careful not to break any plastic clips or pieces or you will need to buy a new unit.
    • To prevent having to disassemble this unit often, always take a few minutes to cut any hair/fibre off of the brush after each use.
    • Disassembly and cleaning should take from 30-45 minutes, depending on how much hair is stuck in the unit.
  2. STB-101 Miele Turbo Mini TurboBrush Disassembly and Cleaning, Opening the Unit: Schritt 2, Bild 1 von 2 STB-101 Miele Turbo Mini TurboBrush Disassembly and Cleaning, Opening the Unit: Schritt 2, Bild 2 von 2
    • Following the instructions in your manual open the unit up. You line up the arrows, push the little plastic button, and slide the rotating cuff up. This should allow the top half of the unit to hinge upwards as shown in this photo.
  3. STB-101 Miele Turbo Mini TurboBrush Disassembly and Cleaning, Remove Fin Assembly: Schritt 3, Bild 1 von 1
    • Now we remove the part that makes the unit spin. The fins are pulled by the vacuum suction and rotate the belt that moves the brush. To remove the Fin assembly, gently squeeze the little black plastic clips on either side. This does not take much force, do it gently as if you break the clips there is no way to repair them.
  4. STB-101 Miele Turbo Mini TurboBrush Disassembly and Cleaning, Remove End Caps: Schritt 4, Bild 1 von 1
    • This is probably the hardest part of the disassembly, certainly the least intuitive. The end caps hold the whole unit together and are just popped in. Gently pry them off pulling them by hand, rotating as much as you can, and then using a small flat-headed screwdriver to pry them off. This will take a little pressure and work.
    • The caps are held on at the centre (see the middle of caps in the photo). This is where you want to focus the pressure when prying. Be careful of plastic clips but apply assertive pressure to pop them off.
  5. STB-101 Miele Turbo Mini TurboBrush Disassembly and Cleaning, Remove Top Half of Unit: Schritt 5, Bild 1 von 1
    • The top half of the unit that hinges upward can be removed by gently bending the plastic edges outward. You should be left with the bottom half and brush assembly as shown in the photo.
  6. STB-101 Miele Turbo Mini TurboBrush Disassembly and Cleaning, Remove Bottom Half of Unit: Schritt 6, Bild 1 von 1
    • Just like the top half, the bottom half of the unit can be removed by gently bending the plastic fins on either side outward and sliding it off of the brush assembly. You will be left with what is shown in the photo.
  7. STB-101 Miele Turbo Mini TurboBrush Disassembly and Cleaning, Remove Brush from Brush Assembly: Schritt 7, Bild 1 von 2 STB-101 Miele Turbo Mini TurboBrush Disassembly and Cleaning, Remove Brush from Brush Assembly: Schritt 7, Bild 2 von 2
    • To remove the brush axle from the brush assembly, pull the little white plastic end cap outward slightly (see second photo). Then you can just pull the brush axle out.
  8. STB-101 Miele Turbo Mini TurboBrush Disassembly and Cleaning, Cleaning Time!: Schritt 8, Bild 1 von 1
    • The unit is now fully disassembled! Clean all the parts. I recommend using a large safety pin. Dig all of the hair/fibres out of the ends of the brush axle and white axle caps especially. Cut all the hair off of the brush unit using scissors. Once everything is clean, use your vacuum to clean all the remaining dust and leftover hair.
  9. STB-101 Miele Turbo Mini TurboBrush Disassembly and Cleaning, Reassembly!: Schritt 9, Bild 1 von 3 STB-101 Miele Turbo Mini TurboBrush Disassembly and Cleaning, Reassembly!: Schritt 9, Bild 2 von 3 STB-101 Miele Turbo Mini TurboBrush Disassembly and Cleaning, Reassembly!: Schritt 9, Bild 3 von 3
    • Just follow the steps in reverse.
    • Fit the belt onto the white gear on the brush assembly. With white end cap pulled out, fit the brush axel into the brush assembly, make sure the belt is in the right place and runs freely. Push the white end cap closed.
  10. STB-101 Miele Turbo Mini TurboBrush Disassembly and Cleaning, Reassembly 2: Schritt 10, Bild 1 von 3 STB-101 Miele Turbo Mini TurboBrush Disassembly and Cleaning, Reassembly 2: Schritt 10, Bild 2 von 3 STB-101 Miele Turbo Mini TurboBrush Disassembly and Cleaning, Reassembly 2: Schritt 10, Bild 3 von 3
    • Attach the bottom half of unit gently over white end caps.
    • Attach the top half of the unit gently over white end caps.
    • Push the black side caps into place. You may have to gently hammer these on so that they "pop" in. Make sure they are in the right place so you don't break off the little plastic tabs inside.
  11. STB-101 Miele Turbo Mini TurboBrush Disassembly and Cleaning, Reassembly 3: Schritt 11, Bild 1 von 2 STB-101 Miele Turbo Mini TurboBrush Disassembly and Cleaning, Reassembly 3: Schritt 11, Bild 2 von 2
    • Put the belt around the Fin unit. make sure the belt can run freely.
    • Gently squeeze the plastic clips to allow them to clip the fin unit into place. Note, these clips fit in in a "vertical" orientation (longest from top to bottom) and the middle part of the clip is what holds the unit in place. Be gentle and do not break this.
    • The top hinge should close easily.
  12. STB-101 Miele Turbo Mini TurboBrush Disassembly and Cleaning: Schritt 12, Bild 1 von 1
    • Hooray! Your Turbo Mini is now as good as new! Just like this stock photo!
Abschluss
20 weitere Nutzer:innen haben diese Anleitung absolviert.
16 Kommentare
Good guiding and easy to follow. 5 stars.
vesen51 - Antwort
Excellent guide, clear and helpful.
I don’t think there’s any need to remove the turbo fan until after the cover is off.
As you say removing the end caps is the hardest bit, and it’s worth saying at the start that they are held on by the studs at the centre, and only the studs, (so people don’t start trying to lever them off at the edge. I don’t think rotating makes any difference.
Note that the two white pieces at each end of the roller are different - the longer one fits in the end with the deeper hole.
But - Thank- you! - as the end pieces are so reluctant to come off that I had previously given up trying to dissemble it.
John - Antwort
PS in the tool list a ‘flat head phillips screwdriver ‘ is nonsense, of course. All you need is a flat headed one with - ideally - a 6-7mm [say 3/8”] wide blade.
John - Antwort
I’d given up on mine working and just looking at it didn’t exactly inspire me how to disassemble it. (I was looking for screws.) Luckily this popped up (I never would have thought something like this would be on ifixit but here we are…) on a web search.
Well explained and now my mini vacuum head is spinning like a champ again. Thanks much.
Matt - Antwort
My first instinct was to check YouTube, but this was the best set of instructions I found. Worked perfectly. Thank you!
Kunal Banerji - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 12
Letzte 7 Tage: 65
Letzte 30 Tage: 234
Insgesamt: 25,346
