Einleitung
This guides enumerates the steps of removing and replacing the front casing of the SPV Aqua 5800 Camera in order to protect the mechanisms within.
Was du brauchst
Locate the two 3.5 mm screws on the side of the device.
Apply pressure to the PH J000 philips head screwdriver and turn in a counter clockwise motion until the screw becomes loose enough to pull out.
Once you have properly removed the strap hook, locate the two 3 mm screws located on the opposite side of the strap hook.
Place the PH J000 phillips head screwdriver on the head of screw; apply pressure and turn in a counter clockwise motion until screws come loose.
Place the plastic opening tool on the crack between the front and back casings.
Apply pressure by pulling down on the plastic opening tool to pry the case apart.
Wedge your fingers in the opening and slowly pull the front casing away from the bottom casing until it complete separates from the device.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
