Zum Hauptinhalt wechseln
SYNOLOGY DS218 +: a complete disassembly in rules
Was du brauchst
  1. SYNOLOGY DS218 +: a complete disassembly in rules, Presentation: the different faces of the case: Schritt 1, Bild 1 von 3 SYNOLOGY DS218 +: a complete disassembly in rules, Presentation: the different faces of the case: Schritt 1, Bild 2 von 3 SYNOLOGY DS218 +: a complete disassembly in rules, Presentation: the different faces of the case: Schritt 1, Bild 3 von 3
    • Here are the different interesting faces of the case: front (bay disks), rear (connectors and fan).
    • This NAS DS218 + is equiped with 2 GB of RAM (6 GB max.), An INTEL Celeron J3355 64-bit Dual core processor, two bays for SATA drives.
    • 1 x RJ45 Gb port.
    • Kensington security incision (K-lock)
    • 1 x port for power supply
    • 3 x USB 3 ports (1 in front and 2 behind)
    • 1 x eSATA port
  2. SYNOLOGY DS218 +: a complete disassembly in rules, Teardown : remove disk media: Schritt 2, Bild 1 von 3 SYNOLOGY DS218 +: a complete disassembly in rules, Teardown : remove disk media: Schritt 2, Bild 2 von 3 SYNOLOGY DS218 +: a complete disassembly in rules, Teardown : remove disk media: Schritt 2, Bild 3 von 3
    • nothing very hard … remove the disk media by pressing "push" buton.
  3. SYNOLOGY DS218 +: a complete disassembly in rules, Backplane and memory slot access: Schritt 3, Bild 1 von 2 SYNOLOGY DS218 +: a complete disassembly in rules, Backplane and memory slot access: Schritt 3, Bild 2 von 2
    • 2 x SATA port
    • Only the empty memory slot is reachable.
    • The one used (memory slot) is not reachable. The case must be unmounted integraly to access to this memory slot (see step 13).
  4. SYNOLOGY DS218 +: a complete disassembly in rules, Case: removing the cover 1/2: Schritt 4, Bild 1 von 2 SYNOLOGY DS218 +: a complete disassembly in rules, Case: removing the cover 1/2: Schritt 4, Bild 2 von 2
    • Remove the screw on the back of the case next to Kensington incision.
    • Fan screws removal is not needed …
  5. SYNOLOGY DS218 +: a complete disassembly in rules, Housing: cover removal 2/2: Schritt 5, Bild 1 von 3 SYNOLOGY DS218 +: a complete disassembly in rules, Housing: cover removal 2/2: Schritt 5, Bild 2 von 3 SYNOLOGY DS218 +: a complete disassembly in rules, Housing: cover removal 2/2: Schritt 5, Bild 3 von 3
    • Once rear screws removed …
    • there are two lock lugs (front panel left side) to unlock.
    • Use a flat screwdriver to pry. Be careful not to twist the metal bar.
    • Then slide the NAS in the direction of the length as in the photos.
  6. SYNOLOGY DS218 +: a complete disassembly in rules, Teardown: internal parts: Schritt 6, Bild 1 von 3 SYNOLOGY DS218 +: a complete disassembly in rules, Teardown: internal parts: Schritt 6, Bild 2 von 3 SYNOLOGY DS218 +: a complete disassembly in rules, Teardown: internal parts: Schritt 6, Bild 3 von 3
    • in orange: internal SATA ports
    • in yellow: fan connector
    • in blu: fan
    • in green: free (empty) memory slot
  7. SYNOLOGY DS218 +: a complete disassembly in rules, Teardown: spacer holding cage and case: Schritt 7, Bild 1 von 3 SYNOLOGY DS218 +: a complete disassembly in rules, Teardown: spacer holding cage and case: Schritt 7, Bild 2 von 3 SYNOLOGY DS218 +: a complete disassembly in rules, Teardown: spacer holding cage and case: Schritt 7, Bild 3 von 3
    • simply unscrew the screw to remove the spacer.
    • you will notice the guides (keying) to position the spacer.
  8. SYNOLOGY DS218 +: a complete disassembly in rules, Disassembly: spacer holding fan: Schritt 8, Bild 1 von 2 SYNOLOGY DS218 +: a complete disassembly in rules, Disassembly: spacer holding fan: Schritt 8, Bild 2 von 2
    • same as before ... unscrew the screw to remove the plastic spacer
    • you will also notice the keysters ...
  9. SYNOLOGY DS218 +: a complete disassembly in rules, Teardown: removal of the fan: Schritt 9, Bild 1 von 2 SYNOLOGY DS218 +: a complete disassembly in rules, Teardown: removal of the fan: Schritt 9, Bild 2 von 2
    • the fan has been removed for the tutorial. This is not mandatory ... but better to have a little more room!
    • Only the connector must be removed for disassembly
    • beware of the tape to take off before!
  10. SYNOLOGY DS218 +: a complete disassembly in rules, Teardown: removal of the motherboard 1/2: Schritt 10, Bild 1 von 3 SYNOLOGY DS218 +: a complete disassembly in rules, Teardown: removal of the motherboard 1/2: Schritt 10, Bild 2 von 3 SYNOLOGY DS218 +: a complete disassembly in rules, Teardown: removal of the motherboard 1/2: Schritt 10, Bild 3 von 3
    • to remove the motherboard from the box, unscrew the 4 screws as below ...
  11. SYNOLOGY DS218 +: a complete disassembly in rules, Teardown: removal of the motherboard 2/2: Schritt 11, Bild 1 von 3 SYNOLOGY DS218 +: a complete disassembly in rules, Teardown: removal of the motherboard 2/2: Schritt 11, Bild 2 von 3 SYNOLOGY DS218 +: a complete disassembly in rules, Teardown: removal of the motherboard 2/2: Schritt 11, Bild 3 von 3
    • once the screws are removed, pull the front slightly outwards ...
    • This allows the front panel connectors to pass through.
    • … then lift up the motherboard by holding the disk cage.
  12. SYNOLOGY DS218 +: a complete disassembly in rules, Teardown: removal of the disk bay: Schritt 12, Bild 1 von 2 SYNOLOGY DS218 +: a complete disassembly in rules, Teardown: removal of the disk bay: Schritt 12, Bild 2 von 2
    • remove the screws marked in yellow (x4)
    • no specific photographs ... nothing very complex!
  13. SYNOLOGY DS218 +: a complete disassembly in rules, Internal parts: case, motherboard: Schritt 13, Bild 1 von 3 SYNOLOGY DS218 +: a complete disassembly in rules, Internal parts: case, motherboard: Schritt 13, Bild 2 von 3 SYNOLOGY DS218 +: a complete disassembly in rules, Internal parts: case, motherboard: Schritt 13, Bild 3 von 3
    • 1 - motherboard (processor side)
    • 2 - motherboard (memory side)
    • 3 - empty case
  14. SYNOLOGY DS218 +: a complete disassembly in rules, Many thanks!: Schritt 14, Bild 1 von 1
    • photograph showing one of the phases of the NAS teardown.
Abschluss
To reassemble your device, follow the instructions in reverse order.
17 weitere Nutzer:innen haben diese Anleitung absolviert.
fr en
100%
Sébastien hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
Sébastien
3.625 Reputation
6 Anleitungen geschrieben
AEM (ANIMA EX MACHINA) Mitglied von AEM (ANIMA EX MACHINA)
Business
1 Mitglied
13 Anleitungen geschrieben
5 Kommentare
Merci, c’est super sympa. Au top tes photos. Ca m’a permis de voir qu’il n’y a pas de ventilateur sur la carte mère.
Je viens d’en acheter un et j’hésite à changer le ventilateur car il est trop bruyant à mon goût, j’ai deux ssd dedans, donc pas de risque de ventilation trop faible. A voir la compatibilité des ventilos maintenant.
Avec ton tuto, je serai bien guidé pour le démontage !
Tanguy Westelynck - Antwort
super tuto qui me serra très utile car je dois changer mon ventilateur ! Merci !
Francesco DE PALMA - Antwort
Muchas gracias. Es igualmente valido para el modelo DS220+. El motivo fue acceder a la pila de la BIOS que había quedado suelta, se encuentra en la parte inferior de la placa, junto a los conectores traseros.
En el paso 4, si recomendaría retirar los tornillos del ventilador.
Amado Gonzalez-Bedoya - Antwort
Many thanks for this article. It is very helpful. Would anybody have a photo of the motherboard (processor side) in a higher resolution?
One IC on my NAS burnt and I am unable to read its value so I can replace it.
Many thanks
Rick - Antwort
Hi Rick,
It's like me ? https://we.tl/t-6yCq1mSDH7
hed -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 12
Letzte 7 Tage: 94
Letzte 30 Tage: 353
Insgesamt: 22,881
