Einleitung
If the water tank drips when it is not installed in the machine, then the water tank seal needs to be replaced. This simple repair will be demonstrate hier. If the water tank loses water while it is inserted in the coffee machine, then the water tank seal in the unit needs to replaced. This is shown here
Was du brauchst
With your fingers press the valve stem from the bottom up . Now you can pry off the seal with a spatula tip.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
