Zum Hauptinhalt wechseln
Samsung 27E510C NAV Button Replacement
Was du brauchst
  1. Samsung 27E510C  NAV Button Replacement, Back Panel: Schritt 1, Bild 1 von 3 Samsung 27E510C  NAV Button Replacement, Back Panel: Schritt 1, Bild 2 von 3 Samsung 27E510C  NAV Button Replacement, Back Panel: Schritt 1, Bild 3 von 3
    • Use the #1 Phillips head screw driver to remove each 13.75mm length screw from the rear panel.
    • The screw alone with the ports is a different size than the rest, its length is 12mm.
  2. Samsung 27E510C  NAV Button Replacement: Schritt 2, Bild 1 von 2 Samsung 27E510C  NAV Button Replacement: Schritt 2, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Heavy-Duty Spudger
    Kaufen
    • Insert the heavy duty spudger in between the monitors back panel and its frame.
    • Use the heavy duty spudger to pry open the back panel.
    • Over aggressive prying could break the tabs holding the back panel in place.
  3. Samsung 27E510C  NAV Button Replacement, Rear navigation button: Schritt 3, Bild 1 von 1
    • Carefully remove the tape holding down the connector wire.
    • You will need to re-attach the tape upon reassembly.
  4. Samsung 27E510C  NAV Button Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the navigation button from the motherboard by holding down the thumb tab and pulling its connector out.
  5. Samsung 27E510C  NAV Button Replacement: Schritt 5, Bild 1 von 2 Samsung 27E510C  NAV Button Replacement: Schritt 5, Bild 2 von 2
    • Remove the navigation buttons connector wire from the monitors body tab.
  6. Samsung 27E510C  NAV Button Replacement: Schritt 6, Bild 1 von 1
    • With one thumb, hold down the tab on the bottom of the navigation buttons base.
    • While holding the tab down, lift the base of the navigation button with your other hand.
  7. Samsung 27E510C  NAV Button Replacement: Schritt 7, Bild 1 von 3 Samsung 27E510C  NAV Button Replacement: Schritt 7, Bild 2 von 3 Samsung 27E510C  NAV Button Replacement: Schritt 7, Bild 3 von 3
    • Remove the connector wire from the defective navigation button by first gripping its connectors thumb tab.
    • While gripping the thumb tab, pull the connector from the base of the navigation button.
    • You can save the connector wire since it may not be defective.
Abschluss
giggythore
366 Reputation
3 Anleitungen geschrieben
Cal Poly, Team S9-G1, Banghart Fall 2017 Mitglied von Cal Poly, Team S9-G1, Banghart Fall 2017
CPSU-BANGHART-F17S9G1
6 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 21
Insgesamt: 516
