Einleitung
The back panel is the "lid" that covers many of the monitors electrical components. Therefore this is a prerequisite for most of the other repair guides on this device.
Was du brauchst
Use the #1 Phillips head screw driver to remove each 13.75mm length screw from the rear panel.
Insert the heavy duty spudger in between the monitors back panel and its frame.
Use the heavy duty spudger to pry open the back panel.
Fast fertig!
Abschluss
