Einleitung
This guide will provide steps on how to remove and replace the Samsung 351 U battery.
Was du brauchst
First, use a #0 Phillips screwdriver to remove the ten 4mm screws on the back of the laptop.
Remove the back cover using a spudger.
Now, detach the wire that is connected to the battery, which should now be removable.
Fast fertig!
Abschluss
