Zum Hauptinhalt wechseln
Samsung 500C ChromeBook Battery Replacement
Was du brauchst
  1. Samsung 500C ChromeBook Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Samsung 500C ChromeBook Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Use the spudger to remove the four rubber feet on the bottom panel.
    • Remove the seven Philips #1 screws.
  2. Samsung 500C ChromeBook Battery Replacement: Schritt 2, Bild 1 von 3 Samsung 500C ChromeBook Battery Replacement: Schritt 2, Bild 2 von 3 Samsung 500C ChromeBook Battery Replacement: Schritt 2, Bild 3 von 3
    • Remove the seven Phillips #1 screws holding the battery in place.
    • Detach the battery connector by pulling the connector towards the battery.
    • Pull from the plastic connector, do not pull from the wires.
    • Remove the battery.
    • When reinserting the battery, it is easier to insert from the long end first before lowering the rest of the battery into place.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Michigan Tech, Team 1-2, Lauer Spring 2014 Mitglied von Michigan Tech, Team 1-2, Lauer Spring 2014
MTU-LAUER-S14S1G2
3 Mitglieder
10 Anleitungen geschrieben
3 Kommentare zur Anleitung
Samsung 500C ChromeBook Battery where to buy?
Uzi Naveh - Antwort
I keep typing charger and all you is replacing the battery. Without a charger I can't know if the battery is bad. Can you help or not???
Carol South - Antwort
Don't show my NAME
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 11
Insgesamt: 3,300
