Zum Hauptinhalt wechseln
Samsung 500C ChromeBook Internal Speakers Replacement
Was du brauchst
  1. Samsung 500C ChromeBook Internal Speakers Replacement, Internal Speakers: Schritt 1, Bild 1 von 2 Samsung 500C ChromeBook Internal Speakers Replacement, Internal Speakers: Schritt 1, Bild 2 von 2
    • Remove the back panel of the device by taking out the seven screws on the back panel of the device.
    • Four of the screws are under the rubber feet so they will need to be removed. To remove the feet, pry them off with the spudger.
    Frag FixBot
    Kommentar hinzufügen
  2. Samsung 500C ChromeBook Internal Speakers Replacement: Schritt 2, Bild 1 von 2 Samsung 500C ChromeBook Internal Speakers Replacement: Schritt 2, Bild 2 von 2
    • Note: The Speaker is held in with an adhesive back so some force will be needed to remove it.
    • Remove the speaker using a spudger and detach the cord connected to it from the laptop. The speaker location is seen highlighted in picture 1.
    • Attach the cord of your replacement speaker and reassemble the device.
    Frag FixBot
Abschluss
Michigan Tech, Team 1-2, Lauer Spring 2014 Mitglied von Michigan Tech, Team 1-2, Lauer Spring 2014
MTU-LAUER-S14S1G2
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 43
Insgesamt: 1,315
