Einleitung
This guide will assist you on replacing a Samsung Remote Model# AH59-02408A’s circuit board. When TV remotes are not functioning, people tend to fear that they cannot fix them because the procedure is too advanced, therefore they resort to buying a replacement remote. However, our tutorial will show you how simple and quick the process of replacing your circuit board is.
*Additional Details/Tips:
- You will not require any tools for this process apart from your replacement circuit board.
- Good organization and reading skills will help you get through the steps quicker
- It is recommended that you perform the replacement in a lighted workspace as it will greatly help you with identifying small alignment nodes/holes.
Separate the front and back case with your hands. Grip it by the seam and open it up gently.
Identify whether the circuit board is secured to the keypad or the back plate.
Pull out the circuit board from the sockets in the back case.
To complete the replacement, follow the steps in reverse order using your new circuit board.
