Einleitung
This computer is equipped with a 1 TB hard drive. Whether the hard drive has went bad and needs replacement or if you want to upgrade to a larger and quicker one, this guide will help you complete this task.
Was du brauchst
Place the computer upside down.
Remove one 6.5mm screw on exterior of computer.
Remove the panel by sliding it down and lifting it away from the computer, exposing the RAM and hard drive.
Remove the four 4.4mm screws securing the hard drive.
Remove the harness from hard drive.
Remove and replace the hard drive.
3 weitere Personen haben diese Anleitung absolviert.
