Zum Hauptinhalt wechseln
Samsung ATIV Book 4 Screen Replacement
Was du brauchst
  1. Samsung ATIV Book 4 Screen Replacement, Screen: Schritt 1, Bild 1 von 2 Samsung ATIV Book 4 Screen Replacement, Screen: Schritt 1, Bild 2 von 2
    • Be sure the computer is off, and open the computer so that the screen is showing.
    • Use the plastic opening tool and pry away the casing surrounding the screen. Remove the casing entirely.
  2. Samsung ATIV Book 4 Screen Replacement: Schritt 2, Bild 1 von 1
    • Remove the four 3.5mm screws securing the screen.
    • Tilt the screen back before removing the screws, there is a possibility it could fall and damage your keyboard or the ribbon cable connected to it.
  3. Samsung ATIV Book 4 Screen Replacement: Schritt 3, Bild 1 von 1
    • Place the screen gently on the keyboard.
  4. Samsung ATIV Book 4 Screen Replacement: Schritt 4, Bild 1 von 1
    • Remove the ribbon cable from the screen.
    • Remove and replace the screen.
Abschluss
Daniel
342 Reputation
3 Anleitungen geschrieben
Michigan Tech, Team 1-7, Lauer Spring 2015 Mitglied von Michigan Tech, Team 1-7, Lauer Spring 2015
MTU-LAUER-S15S1G7
2 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
Where do you buy the replacement screen for the ATIV Book 4? Thanks!
RMS015 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 12
Insgesamt: 3,396
