Einleitung
This replacement guide will aid the replacement of the speakers showing you a thorough breakdown on what steps to follow to achieve this task efficiently.
Was du brauchst
Remove the ten 5 mm screws that hold the backplate using the Phillips #000 screwdriver.
Remove the six 5mm screws that hold the battery by using the Phillips #0 screwdriver.
There are two speakers which are found on the lower left and right side of the laptop, beside the battery.
Remove the screws of the motherboard to disconnect the motherboard from the speakers using a Phillips #0 screwdriver.
Remove the 4 mm screw with the Phillips #000 screwdriver and remove the speaker.
Eine weitere Person hat diese Anleitung absolviert.
