Einleitung
This guide may be used to remove the computer board that operates the Audio, USB2, and Display Ports from the Samsung ATIV Book 9 Lite for replacement. Have a Phillips screwdriver ready. Be sure to keep track of all screws removed and where they belong. When removing the audio port, be sure not to damage any cords connecting the charging port to the laptop. Dispose of the broken audio port properly.
Was du brauchst
Turn the laptop upside down to show the screws holding the back cover on.
Using a Phillips #0, remove the ten 4mm screws located around the edges and one central.
Using your hands move the black and white wires that are layered on top of the board to be out of the way of the removal.
Using a Phillips #0, remove three 3.5mm screws.
Using your hands remove the cord that connects the speakers to the board you are removing.
Using your hands, remove the board from the computer.
