Zum Hauptinhalt wechseln
Samsung ATIV Book 9 Lite Battery Replacement
Was du brauchst
  1. Samsung ATIV Book 9 Lite Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Samsung ATIV Book 9 Lite Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Put a protective lining such as a piece of cloth in between the screen and the keyboard when closed to protect your screen when performing this replacement.
    • Turn the laptop upside down to show the screws holding the back cover on.
    • Using a Phillips #0, remove the ten 4mm screws located around the edges and one central.
  2. Samsung ATIV Book 9 Lite Battery Replacement: Schritt 2, Bild 1 von 3 Samsung ATIV Book 9 Lite Battery Replacement: Schritt 2, Bild 2 von 3 Samsung ATIV Book 9 Lite Battery Replacement: Schritt 2, Bild 3 von 3
    • Use two plastic opening tools to separate the back cover from the laptop.
    • This may take some force because the back cover is snapped into place before the screws are used to keep it in place.
  3. Samsung ATIV Book 9 Lite Battery Replacement: Schritt 3, Bild 1 von 3 Samsung ATIV Book 9 Lite Battery Replacement: Schritt 3, Bild 2 von 3 Samsung ATIV Book 9 Lite Battery Replacement: Schritt 3, Bild 3 von 3
    • Using a Phillips #0, remove the seven 5mm screws highlighted in the image.
    • Using your hands, disconnect the battery's main cord from the main motherboard.
  4. Samsung ATIV Book 9 Lite Battery Replacement: Schritt 4, Bild 1 von 2 Samsung ATIV Book 9 Lite Battery Replacement: Schritt 4, Bild 2 von 2
    • Using your hands remove the battery from the computer.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Phat Tran
786 Reputation
5 Anleitungen geschrieben
Washington State, Team S2-G5, Hope Fall 2018 Mitglied von Washington State, Team S2-G5, Hope Fall 2018
WSU-HOPE-F18S2G5
4 Mitglieder
2 Kommentare
please where can i get the battery 🔋
Bethel Ugwudike - Antwort
Please where can i get the battery for Samsung 930x5j910s5j940x5j
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 1,672
