Zum Hauptinhalt wechseln
Samsung ATIV Book 9 Lite Hard Drive Replacement
Was du brauchst
  1. Samsung ATIV Book 9 Lite Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 2 Samsung ATIV Book 9 Lite Hard Drive Replacement, Hard Drive: Schritt 1, Bild 2 von 2
    • Put a protective lining such as a piece of cloth in between the screen and the keyboard when closed to protect your screen when performing this replacement.
    • Turn the laptop upside down to show the screws holding the back cover on.
    • Using a Phillips #0, remove the ten 4mm screws located around the edges and one central.
  2. Samsung ATIV Book 9 Lite Hard Drive Replacement: Schritt 2, Bild 1 von 3 Samsung ATIV Book 9 Lite Hard Drive Replacement: Schritt 2, Bild 2 von 3 Samsung ATIV Book 9 Lite Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Use two plastic opening tools to separate the back cover from the laptop.
    • This may take some force because the back cover is snapped into place before the screws are used to keep it in place.
  3. Samsung ATIV Book 9 Lite Hard Drive Replacement: Schritt 3, Bild 1 von 3 Samsung ATIV Book 9 Lite Hard Drive Replacement: Schritt 3, Bild 2 von 3 Samsung ATIV Book 9 Lite Hard Drive Replacement: Schritt 3, Bild 3 von 3
    • Using your hands or a plastic opening tool, release the yellow motherboard connection strip on both ends by lifting the clamps.
    • Remove the strip to reveal the hard drive.
  4. Samsung ATIV Book 9 Lite Hard Drive Replacement: Schritt 4, Bild 1 von 2 Samsung ATIV Book 9 Lite Hard Drive Replacement: Schritt 4, Bild 2 von 2
    • Using a Phillips #0, remove the two 3mm screws holding the hard drive in place.
    • Remove the hard drive by pulling it out with your hands.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Phat Tran
786 Reputation
5 Anleitungen geschrieben
Washington State, Team S2-G5, Hope Fall 2018 Mitglied von Washington State, Team S2-G5, Hope Fall 2018
WSU-HOPE-F18S2G5
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 36
Insgesamt: 4,641
