Zum Hauptinhalt wechseln
Samsung ATIV Book 9 NP900X3K-S01US SSD Replacement
Was du brauchst
  1. Samsung ATIV Book 9 NP900X3K-S01US SSD Replacement, SSD: Schritt 1, Bild 1 von 1
    • Remove ten Phillips #00 screws from the back panel.
    • Remove the back panel.
  2. Samsung ATIV Book 9 NP900X3K-S01US SSD Replacement: Schritt 2, Bild 1 von 1
    • Unscrew the five Phillips #00 screws which connect the battery to the frame of the laptop.
    • Lift the battery from the bottom edge, taking care as it is disconnected from the motherboard.
    • During reassembly, insert the top edge of the battery first, aligning the pins of the battery with the pins of the motherboard connection.
  3. Samsung ATIV Book 9 NP900X3K-S01US SSD Replacement: Schritt 3, Bild 1 von 1
    • Remove the interconnect ribbon cable labeled “main” and “sub” by prying the pin connections up with a spudger or plastic opening tool.
  4. Samsung ATIV Book 9 NP900X3K-S01US SSD Replacement: Schritt 4, Bild 1 von 1
    • Remove the single screw holding down the SSD with a Phillips #00 screwdriver.
    • Remove the SSD from its slot located to the right, just above the battery.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 22
Insgesamt: 796
