Einleitung
This guide will show the replacement of the solid state drive (SSD) of the Samsung ATIV Book 9 NP900X3K-S01US.
Was du brauchst
Unscrew the five Phillips #00 screws which connect the battery to the frame of the laptop.
Lift the battery from the bottom edge, taking care as it is disconnected from the motherboard.
Remove the interconnect ribbon cable labeled “main” and “sub” by prying the pin connections up with a spudger or plastic opening tool.
Remove the single screw holding down the SSD with a Phillips #00 screwdriver.
Remove the SSD from its slot located to the right, just above the battery.
Eine weitere Person hat diese Anleitung absolviert.
