Einleitung
This guide will show you how to remove the back cover to the laptop.
Was du brauchst
Turn the laptop upside down so that the underside of the laptop is facing you.
Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
3 weitere Personen haben diese Anleitung absolviert.
