Zum Hauptinhalt wechseln
Samsung ATIV Book 9 Plus Charger Port Replacement
Was du brauchst
  1. Samsung ATIV Book 9 Plus Charger Port Replacement, Back Cover: Schritt 1, Bild 1 von 3 Samsung ATIV Book 9 Plus Charger Port Replacement, Back Cover: Schritt 1, Bild 2 von 3 Samsung ATIV Book 9 Plus Charger Port Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Charger Port Replacement: Schritt 2, Bild 1 von 1
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Charger Port Replacement, Charger Port: Schritt 3, Bild 1 von 2 Samsung ATIV Book 9 Plus Charger Port Replacement, Charger Port: Schritt 3, Bild 2 von 2
    • Unscrew the 4.3mm screws holding down the plastic cover using a #000 screwdriver. After the screws are out remove the cover.
    • Remove the 4.3 mm screw holding down the metal cover using a #000 screwdriver.
  4. Samsung ATIV Book 9 Plus Charger Port Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the charging port from the motherboard by gently tugging on the plastic part of the connection.
  5. Samsung ATIV Book 9 Plus Charger Port Replacement: Schritt 5, Bild 1 von 1
    • Wedge a plastic opening tool or spudger in between the laptop casing and the port. Pry until you feel it release.
    • This will take some force because the port is glued to the casing.
  6. Samsung ATIV Book 9 Plus Charger Port Replacement: Schritt 6, Bild 1 von 1
    • Remove the disconnected charger port.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Casey Kauffman
329 Reputation
2 Anleitungen geschrieben
IUPUI, Team S6-G6, Baechle Fall 2017 Mitglied von IUPUI, Team S6-G6, Baechle Fall 2017
IUPUI-BAECHLE-F17S6G6
3 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 1,920
