Zum Hauptinhalt wechseln
Samsung ATIV Book 9 Plus Heatsink Assembly Replacement
Was du brauchst
  1. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Back Cover: Schritt 1, Bild 1 von 3 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Back Cover: Schritt 1, Bild 2 von 3 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: Schritt 2, Bild 1 von 1
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Internal Fans: Schritt 3, Bild 1 von 3 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Internal Fans: Schritt 3, Bild 2 von 3 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Internal Fans: Schritt 3, Bild 3 von 3
    • The fans should be in the upper left corner of the laptop if the laptop is oriented with the battery in the bottom half.
    • Gently lift the fans' black connector strip out of the way.
  4. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: Schritt 4, Bild 1 von 2 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: Schritt 4, Bild 2 von 2
    • Using a Phillips head screwdriver, unscrew four 4.55 mm Phillips #000 screws that bind the fans.
  5. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the white connectors by gently tugging on them.
    • Lift the fans from their positions.
  6. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Heatsink Assembly: Schritt 6, Bild 1 von 1
    • Using a Phillips head screwdriver #000 unscrew the motherboard from the rest of the components.
  7. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: Schritt 7, Bild 1 von 1
    • Disconnect the two cables shown in the picture by gently pulling them off.
  8. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: Schritt 8, Bild 1 von 1
    • Using a Phillips #000 screwdriver, unscrew the three labeled screws to detach the heatsink assembly.
Abschluss
Ryan Smith
193 Reputation
2 Anleitungen geschrieben
IUPUI, Team S7-G7, Wilson Spring 2019 Mitglied von IUPUI, Team S7-G7, Wilson Spring 2019
IUPUI-WILSON-S19S7G7
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 12
Insgesamt: 625
