Zum Hauptinhalt wechseln
Samsung ATIV Book 9 Plus Speakers Replacement
Was du brauchst
  1. Samsung ATIV Book 9 Plus Speakers Replacement, Back Cover: Schritt 1, Bild 1 von 3 Samsung ATIV Book 9 Plus Speakers Replacement, Back Cover: Schritt 1, Bild 2 von 3 Samsung ATIV Book 9 Plus Speakers Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Speakers Replacement: Schritt 2, Bild 1 von 1
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Speakers Replacement, Speakers: Schritt 3, Bild 1 von 2 Samsung ATIV Book 9 Plus Speakers Replacement, Speakers: Schritt 3, Bild 2 von 2
    • The speakers are black, and form a block-like "L" shape around the bottom half of the battery.
    • Lift from the corners of the speakers to remove them.
  4. Samsung ATIV Book 9 Plus Speakers Replacement: Schritt 4, Bild 1 von 2 Samsung ATIV Book 9 Plus Speakers Replacement: Schritt 4, Bild 2 von 2
    • After lifting the body of the speaker out of the laptop, you will notice that the top of the speaker is connected to the laptop by cables.
    • Continue removing the speakers by gently squeezing the sides of the white connector.
  5. Samsung ATIV Book 9 Plus Speakers Replacement: Schritt 5, Bild 1 von 1
    • Gently tug on the white connector in order to remove the speakers.
Abschluss
Karoline DaVee
136 Reputation
1 Anleitung geschrieben
Baylor, Team 2-3, Grigsby Spring 2015 Mitglied von Baylor, Team 2-3, Grigsby Spring 2015
BU-GRIGSBY-S15S2G3
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 6
Insgesamt: 1,485
