Zum Hauptinhalt wechseln
Samsung ATIV Smart PC 500T Left Speaker Replacement
Was du brauchst
  1. Samsung ATIV Smart PC 500T Left Speaker Replacement, Backplate: Schritt 1, Bild 1 von 2 Samsung ATIV Smart PC 500T Left Speaker Replacement, Backplate: Schritt 1, Bild 2 von 2
    • Remove the stylus from the device.
    • Place the device screen-up on a hard surface, like a table.
  2. Samsung ATIV Smart PC 500T Left Speaker Replacement: Schritt 2, Bild 1 von 3 Samsung ATIV Smart PC 500T Left Speaker Replacement: Schritt 2, Bild 2 von 3 Samsung ATIV Smart PC 500T Left Speaker Replacement: Schritt 2, Bild 3 von 3
    • Insert a plastic pry tool or opening pick between the glass and plastic case.
    • Work your way around the plastic edge, unclipping the backplate.
    • Once the clips are loosened, remove the backplate. Some force may be necessary.
    • Though you may need to use force, be careful of the pry tool slipping and hurting you!
  3. Samsung ATIV Smart PC 500T Left Speaker Replacement, Battery: Schritt 3, Bild 1 von 3 Samsung ATIV Smart PC 500T Left Speaker Replacement, Battery: Schritt 3, Bild 2 von 3 Samsung ATIV Smart PC 500T Left Speaker Replacement, Battery: Schritt 3, Bild 3 von 3
    • Disconnect the three ribbon cables from the motherboard to free the battery.
    • Use your finger to lift the flap securing each ZIF connector.
    • Slide the ribbon cable out and towards you. Now it should be completely detached.
    • Repeat with the other two cables.
  4. Samsung ATIV Smart PC 500T Left Speaker Replacement: Schritt 4, Bild 1 von 3 Samsung ATIV Smart PC 500T Left Speaker Replacement: Schritt 4, Bild 2 von 3 Samsung ATIV Smart PC 500T Left Speaker Replacement: Schritt 4, Bild 3 von 3
    • Get a firm hold of the power cable as close to the clip as you can.
    • Pull the power cable up and out of the clip.
  5. Samsung ATIV Smart PC 500T Left Speaker Replacement: Schritt 5, Bild 1 von 3 Samsung ATIV Smart PC 500T Left Speaker Replacement: Schritt 5, Bild 2 von 3 Samsung ATIV Smart PC 500T Left Speaker Replacement: Schritt 5, Bild 3 von 3
    • Remove the six 3.5-mm screws using the Phillips #00 screwdriver.
    • Lift the battery out by hooking your finger under the tab on the top side of the battery and pulling it up and towards you. The battery should come out easily.
  6. Samsung ATIV Smart PC 500T Left Speaker Replacement, Left Speaker: Schritt 6, Bild 1 von 2 Samsung ATIV Smart PC 500T Left Speaker Replacement, Left Speaker: Schritt 6, Bild 2 von 2
    • Locate the left speaker.
    • The left speaker is labeled with an "L."
    • Locate the 3.5-mm screws and remove them with the Phillips #00 Screwdriver.
  7. Samsung ATIV Smart PC 500T Left Speaker Replacement: Schritt 7, Bild 1 von 1
    • Once the screws have been removed, lift and remove the speaker from the device.
Abschluss
Crystal Dinh
1.026 Reputation
4 Anleitungen geschrieben
Baylor, Team 6-6, Williams Fall 2015 Mitglied von Baylor, Team 6-6, Williams Fall 2015
BU-WILLIAMS-F15S6G6
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 984
