Zum Hauptinhalt wechseln
Samsung Ace Casing Replacement
Was du brauchst
  1. Samsung Ace Casing Replacement, Battery: Schritt 1, Bild 1 von 3 Samsung Ace Casing Replacement, Battery: Schritt 1, Bild 2 von 3 Samsung Ace Casing Replacement, Battery: Schritt 1, Bild 3 von 3
    • To remove the back casing, firmly press down and push towards the bottom of the phone.
  2. Samsung Ace Casing Replacement: Schritt 2, Bild 1 von 1
    • With the casing removed, lift the battery from the indicated indentation.
  3. Samsung Ace Casing Replacement: Schritt 3, Bild 1 von 1
    • From here, you can now access the SIM card and model/serial numbers.
  4. Samsung Ace Casing Replacement, Casing: Schritt 4, Bild 1 von 1
    • Using the Phillips #00 screwdriver, remove the four indicated screws (4.5 mm).
  5. Samsung Ace Casing Replacement: Schritt 5, Bild 1 von 2 Samsung Ace Casing Replacement: Schritt 5, Bild 2 von 2
    • Press the pointed edge of the spudger into the side of the two rubber plugs in order to lift and remove them from the top of the phone.
    • Then, using the Phillips #00 screwdriver, remove the two indicated Phillip screws (6.5 mm).
  6. Samsung Ace Casing Replacement: Schritt 6, Bild 1 von 1
    • To remove the SIM card, start by pressing the top of the card and push down and away towards the bottom of the phone. Then, as indicated, pull the SIM card out.
  7. Samsung Ace Casing Replacement: Schritt 7, Bild 1 von 2 Samsung Ace Casing Replacement: Schritt 7, Bild 2 von 2
    • Begin to slowly lift the back casing of the phone. You should hear a snap when the casing is released.
    • The power, volume, and camera buttons may fall out when separating the front and back casing.
  8. Samsung Ace Casing Replacement: Schritt 8, Bild 1 von 1
    • Your casing should be separated and the three loose buttons put to the side.
    • Be aware of the wiring on the top of the phone. Make sure not to pull it apart when separating the case.
  9. Samsung Ace Casing Replacement: Schritt 9, Bild 1 von 2 Samsung Ace Casing Replacement: Schritt 9, Bild 2 von 2
    • Slowly remove the back casing by gently pulling the ribbon connection.
  10. Samsung Ace Casing Replacement: Schritt 10, Bild 1 von 2 Samsung Ace Casing Replacement: Schritt 10, Bild 2 von 2
    • Gently pull on the wires to remove the front casing.
  11. Samsung Ace Casing Replacement: Schritt 11, Bild 1 von 1
    • Your front casing and front speaker are now released.
Abschluss
Breanne
187 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 6-24, Amido Spring 2012 Mitglied von Cal Poly, Team 6-24, Amido Spring 2012
CPSU-AMIDO-S12S6G24
3 Mitglieder
15 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 819
