Einleitung
This guide provides an outline of how to remove and replace the hinge in the Samsung Alias 2. The hinge holds the phone together and allows the spring action of the flip phone. This repair would need to happen if the phone is unable to close or if it is in 2 seperate pieces.
Was du brauchst
Pull the two halves of the phone apart.
The phone will not slide straight apart. You have to angle the back half up a little.
Do not force it. Jiggle it a little if it doesn't come apart.
Pop out the top half of the hinge with the plastic opening tool. This will release the hinge cover for removal.
Remove the Verizon logo from the back of phone using the plastic opening tool.
Remove the four 4.44 mm screws from the back.
Remove the three 4.35mm screws from under the Verizon logo.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
