Zum Hauptinhalt wechseln
Samsung BD-D5500 Disc Tray Replacement
Was du brauchst
  1. Samsung BD-D5500 Disc Tray Replacement, Samsung BD-D5500 Disassembly: Schritt 1, Bild 1 von 1
    • To begin, turn the device over so that the bottom is facing up. There are 9 black clips that attach the plastic body to the case. Remove these clips from the case.
  2. Samsung BD-D5500 Disc Tray Replacement: Schritt 2, Bild 1 von 2 Samsung BD-D5500 Disc Tray Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #2 screwdriver to remove the screw that attaches the top cover to the rear of the device. This will allow you to remove the cover.
    • This is how your device will look after you remove the top.
  3. Samsung BD-D5500 Disc Tray Replacement, Disc Tray: Schritt 3, Bild 1 von 1
    • To remove the disc hub all you have to do is remove the 4 screws holding it down.
  4. Samsung BD-D5500 Disc Tray Replacement: Schritt 4, Bild 1 von 1
    • To replace the disc tray open the disk hub and unsnap the sides of the device.
  5. Samsung BD-D5500 Disc Tray Replacement: Schritt 5, Bild 1 von 1
    • Locate the slider that reads open and close.
    • To open the disc tray slide it to the side that says open.
  6. Samsung BD-D5500 Disc Tray Replacement: Schritt 6, Bild 1 von 1
    • Return it face up and the disc tray will slide out.
Abschluss
Brandon Nelson
109 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 25
Insgesamt: 1,380
