Einleitung
This guide details the process of replacing the player's power supply module. The power supply is mainly responsible for powering on the device so this may answer many problems concerning this issue.
  1. To begin, turn the device over so that the bottom is facing up. There are  9 black clips that attach the plastic body to the case.  Remove these clips from the case.
    • To begin, turn the device over so that the bottom is facing up. There are 9 black clips that attach the plastic body to the case. Remove these clips from the case.
  2. Use a Phillips #2 screwdriver to remove the screw that attaches the top cover to the rear of the device.  This will allow you to remove the cover. This is how your device will look after you remove the top.
    • Use a Phillips #2 screwdriver to remove the screw that attaches the top cover to the rear of the device. This will allow you to remove the cover.
    • This is how your device will look after you remove the top.
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Unscrew the 1.2mm screws labeled with a red circle and remove the power supply from the player.
    • Unscrew the 1.2mm screws labeled with a red circle and remove the power supply from the player.
  5. Labeled with a red rectangle is the location where they are connected. Grab the motherboard in one hand and the power supply in the other, and pull the motherboard up and push the power supply down. The motherboard and power supply should then disconnect.
    • Labeled with a red rectangle is the location where they are connected. Grab the motherboard in one hand and the power supply in the other, and pull the motherboard up and push the power supply down. The motherboard and power supply should then disconnect.
Abschluss
Trevor Neman
281 Reputation
2 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 89
